Venu360 - No Firmware Found, USB Ready (or other startup/lock up errors)
To reflash the firmware:
Here is the procedure (you will just need a USB Cable and a Windows PC to perform this)
1) Erase the firmware, while powering up press and hold buttons EDIT + RECALL and wait until the countdown finishes and the firmware is erased
2) Use the manufacturing updater to reinstall the firmware
https://help.harmanpro.com/venu360-manufacturing-updater
The .zip that contains the files for the updater are listed on the right under Downloads - Venu360ManufacturingUpdater.zip
Extract all of the files into the same directory.
If you run into any issues with the utility or performing the update contact Tech Support (details in Signature)
