Hsssss in driverack pa2
Hello, I have a problem, I am tri-amp speakers and when I turn on the PA2 it begins to sound quite a loud hssssssss that does not disappear at any time, nor does it lower its level, even if I put music the hsssss is still heard
Is there a solution?
i am using it on a hi fi system
Regards
Regards
Have you adjusted the back switch from +4dBv to -10dBu? Try that and see if the hiss goes away
If you bypass the PA2 does the hiss go away?
Hello, I have the same problem, even with the muted outputs the noise remains. Have you solved the problem?
Thank you
