Home dbx User Forum dbx General Discussion
Very low input meter readings.
Hello everyone. I'm coming up short on a fix for an issue I'm experiencing with my Venu360. While setting my gain structure if I have my Allen & Heath Zed10fx sending a unity 0 db signal to my 360 the input meters are showing a really quiet signal, just shy of -20 db. I have explored every setting on the app as well as through the menu's on the unit, I have read through the manual and I can't find any explanation on how to get the input signal stronger. I'm assuming there is an input sensitivity setting somewhere, I found the section where you can set the clip meter sensitivity but when I make adjustments there it doesn't effect the signal. Its also not the mixer, I have experienced the low input strength using other mixers as well. Any insight to this issue?
Thank you
  • EEldeEElde Posts: 1,376
    Thank you
    You can go into the mixer of the inputs via the app or the front panel and raise the level of the inputs -
  • Thank you for the response. So there is nothing to worry about if I run these faders higher than 0db?
    No, you should know what headroom and level your amp/speakers should be able to handle as well. As long as everything is good there, then no problem
