DBX Driverack PA2 problems
Hi there,
I recently purchased a Driverack PA2 but I immediately ran into problems. After adjusting some settings and loading a few different presets the system blocks and I can't do anything with it. The only solution is powering off and restart again.
Now I deleted the firmware completely and installed the firmware again (using latop and SUB cable as described several times in this forum) but the problem persists. After installing the new firmware I used the device for approx 2 hours and during those 2 hours I loaded approx 8 different presets and then the system was stuck again.
Any thoughts what might be the problem?
1
SUB cable is USB cable of course :-)
If the Manufacturing Firmware Updater does not resolve the issue, then if you are in your retail return window, I would exchange it for a new unit or refund. You also have the option of sending it in for a warranty repair if bought in the US from an authorized dealer you can contact us (info in my signature below)
hola amigo solucionaste tu problema
