Bluetooth partybox 300 software 151110
Hello people !
I don't know if I posted at the right place, but come on.
I have a jbl partybox 300 box. Since my tv has no bluetooth audio output, I use a p2 cable headphone output on the aux input of the box. Wanting to eliminate the cable, I bought a bluetooth dongle transmitter / receiver tx / rx. Only in this box he always connects normal, only sometimes sound comes out, sometimes not. Stay connected but mute. I have 2 more cx jbl and in them always works.
Will it be bluetooth incompatibility? Has anyone had this problem?
The software my partybox 300 is 151110.
Is there new software that fixes this?
1
my jbl partybox 300 won't update. I have 341219 before, I tried to update it to 381221 but instead it should have a highier version it went back to 151110. I suspect the usb drive but I tried several usb drive it still wont update. Until now its at version 151110. Yes i reformated my usb to fat32 only the Harman_G15.HUI file that is inside my usb drive still failure. I even tried the Harman_G1.HUI and it has same result . It stays at 151110 version. Is there any special USB drive needed .... Please help.
hej.
ny här, jag har precis samma problem och jag har mailat supporten (vilket jag antar att du också gjort) väntar på svar och får jag ngt matnyttigt så informerar jag dig (har också mjukvara 151110) och en av 241531, får du ngn annan info på annat ställe så får du gärna skriva en rad här.
hade också en liten fundering om USB minnet var av fel sort/utförande (kingston 32GB) men vi får se vad jag erhåller för svar
mvh / Lelle
Hi, if you contact Harmen they will send you the laster version, G15.HUI file (firmware 381221)
This worked for me when I upgraded both of my Partybox 300's from firmware 341219 to 381221, which is an important upgrade if there is also a problem connecting the TWS mode.
Where can i download the latest frimware?
Deze heeft nu 20115.
Hi I have a JBL Partybox 300 with the Firmware 371745 I will like to get the new Firmware
Hi How can I get the Firmware for the Partybox 300
Meine Partybox 300 verbindet sich nicht mit meinem neuen Handy über Bluetooth(Version 151110). Ich hoffe ein Software-Update kann den Fehler beheben. Können Sie mir helfen? Bitte an stefanschwarz42@googlemail.com senden, Danke
Hello! It seems you're dealing with a Bluetooth issue on your JBL PartyBox 300. Upgrading to the latest software version may help resolve this, as it often includes bug fixes. Reach out to JBL support for assistance. Good luck!
Hi team,
Can you sent me the party box 300 new update firmware?
i see many user requested firmware update of partybox 300. pls help to send my by email : samypech@gmail.com or comment link download here. Thanks
