JBL Eon One Compact - Disable Bluetooth Pairing
Every time I am using the Eon One Compact and my phone gets near it, the unit attempts to pair to the phone. This is OFTEN not desired. I could not find in the user guide how to disable bluetooth pairing. Please advise.
2
Hi, I have just discovered this forum. I see you asked this question a month ago with no reply which is disappointing. I asked this same question last year to the Harmon support team in the UK and was told the bluetooth or its bleapy alert noise can't be deactivated. I find it really annoying. The blue tooth alert sound is so loud too. Its not professional - especially when I am set up with my piano for wedding ceremonies. I hope they will recognise this is a problem and fix it
Hi Nigel, Thanks for the info. My unit seems to be doing this even more often than before. It is ridiculously annoying. I can't believe that JBL can be so mindless in their development and maintenance of the product and its firmware...
Still no response from JBL Harmon?
Also recommend you do a 'Factory Reset' after installing the new app.
I'm running the app on a cheap Samsung tablet, which gives you a more detailed view and makes it easier to set parameters and add new scenes.
BT broadcast works flawlessly. Once set up, you don't even have to open the app. Just turn the speakers on and you're in business.
