Home Lexicon User Forum Lexicon Software
PCM Native Effects Bundle: polarity switch does not works in all effects
ab459ab459 Posts: 16
edited January 2019 in Lexicon Software
Hi
In all PCM Native Effects Bundle plugins does not works the polarity switch button. Ie, polarity button can be switch by click visually in UI, but no produce any audible effect. (In Chorus, Dual delay, Random Delay etc.)
You can verify this also by checking the shape of output signal thru oscilloscope.
As well, judge by analyzer, the polarity mode currently is in "Inverted" mode permanently, in all this plugs.
I already wrote about it a couple years ago, but it still without changes.
  • ab459ab459 Posts: 16
    Up
  • EEldeEElde Posts: 1,376
    This has been reported to Engineering and they are working on a fix ASAP.
    Thanks!
    Well, sounds good.
    First time it was reported to engineering 5 years ago. So, maybe at least someday at retired i can take advantage of this heh.
    @ab459 said:
    Well, sounds good.
    I'm not aware of any previous escalations. Only the one we put in recently
    Hi
    Sorry, i did check in new version, polarity feature still broken unfortunately.
    Tested at: VST2 version, Win10, Studio One 6
  • HARMAN_PKarrHARMAN_PKarr Posts: 49
    @ab459 said:
    Hi
    Understood, I will report it to the team. Thank you for the feedback!
  • yazanyazan Posts: 13
    @HARMAN_PKarr
    and do not forget about the GUI resize, we need a bigger interface. It is not 2015 anymore ;)
