Home Lexicon User Forum Lexicon Software
Lexicon Lambda - ASIO
My guitar software does not see an ASIO driver for my Lambda with the 2.7 driver for windows 10.
  • mdillardmdillard Posts: 2
    That's GTR3, and POD Farm 2
  • EEldeEElde Posts: 1,376
    With Windows 10, you may need to disable Windows Driver Signing enforcement for the Alpha driver to install correctly. First uninstall the Alpha driver using this utility:
    https://www.iobit.com/en/advanceduninstaller.php
    Then before installing the Alpha driver, follow these steps:
    WINDOWS 10 OPERATING SYSTEM NOTIFICATION
    Windows 10 enforces driver signatures by default. This can be disabled to install drivers that are not digitally signed. Use the following steps to disable driver signature enforcement.
    Click the Start menu and select Settings.
    Click Update and Security.
    Click on Recovery.
    Click Restart now under Advanced Startup.
    Click Troubleshoot.
    Click Advanced options.
    Click Startup Settings.
    Click on Restart.
    On the Startup Settings screen press 7 or F7 to disable driver signature enforcement.
    Your computer will restart and you will be able to install non-digitally signed drivers. If you restart your computer again the driver signature enforcement will be re-enabled.
