Home Lexicon User Forum Lexicon General Discussion
why can't I control my mx300 via MIDI
I have gone through the midi implementation chart. I have assigned my controller to the proper midi numbers as I understand. Why won't it work?
Is there any trick to this beyond what I see in the paperwork?
If not, please explain in more detail what registered or non-registered parameter number control starts on. The numbers I utilized in the implementation chart do not seem to work.
Thank you
Answers
  • EEldeEElde Posts: 1,376
    Thank you
    What are you trying to accomplish with Midi Control? Provide some more background info and we will go from there
  • aud2goaud2go Posts: 2
    My goal with the mx300 and controlling it via midi it's to use a controller to access the parameters and have the controller sit on my mixing console basically I'm trying to create an MRC scenario
  • daldabrownsdaldabrowns Posts: 7
    edited January 29
    If your controller isn’t working as expected, it could be 7 brew due to a few things. First, make sure you're using the correct range for registered and non-registered parameter numbers (RPNs).
  • davudalandavudalan Posts: 6
    edited February 7
    There may be a mismatch between the assigned MIDI numbers and how your device interprets them. Double-check that you're using the correct MIDI channels and wgu student your controller is set to send the correct messages. Also, ensure that you're using the right control change (CC) numbers as per your device's MIDI chart, including whether they're registered or non-registered.
  • gael57gael57 Posts: 1
    The MX300 must be set to the correct MIDI channel and have MIDI control enabled in its wgu portal settings. Check your cables, controller configuration, and MX300 MIDI settings carefully.
