Home Lexicon User Forum Lexicon General Discussion
Lexicon io82 driver problem
I have a problem with the io 82 driver. When i put windows 10 on my com, on desktop, every connection with the driver of the io 82 (youtube, cubase....etc) i have a blue screen. And i tried the same at the laptot, it was without problem. Please help !
Thank you !
Answers
  • EEldeEElde Posts: 1,376
    Make sure you are using the latest Windows driver here:
    https://lexiconpro.com/en-US/softwares/i-o-82-driver-v2-9-77-windows-64-bit
    Also disable driver signing when you install this:
    WINDOWS 10 OPERATING SYSTEM NOTIFICATION
    Windows 10 enforces driver signatures by default. This can be disabled to install drivers that are not digitally signed. Use the following steps to disable driver signature enforcement.
    Click the Start menu and select Settings.
    Click Update and Security.
    Click on Recovery.
    Click Restart now under Advanced Startup.
    Click Troubleshoot.
    Click Advanced options.
    Click Startup Settings.
    Click on Restart.
    On the Startup Settings screen press 7 or F7 to disable driver signature enforcement.
    Your computer will restart and you will be able to install non-digitally signed drivers. If you restart your computer again the driver signature enforcement will be re-enabled.
