Home Lexicon User Forum Lexicon Software
PCM Total Bundle and Ventura
Hi
Just echoing an earlier post regarding PCM Bundle crashing Logic. I've tracked it down to the Lex Chamber causing the error shown in the crash report snippet below. It's repeatable and out of the PCM Total bundle I've tested all the plugins and all are fine except for the Lex Chamber.
Regards
Nick
Process: Logic Pro X [2438]
Path: /Applications/Logic Pro X.app/Contents/MacOS/Logic Pro X
Identifier: com.apple.logic10
Version: 10.7.9 (5830)
Build Info: MALogic-5830000000000000~3 (1A73)
App Item ID: 634148309
App External ID: 857501258
Code Type: X86-64 (Native)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2023-10-20 10:25:31.8959 +0100
OS Version: macOS 13.6 (22G120)
Report Version: 12
Bridge OS Version: 8.0 (21P365)
Anonymous UUID: 10E5311C-A204-99A8-835E-B6511D5944F4
Time Awake Since Boot: 1500 seconds
System Integrity Protection: enabled
Crashed Thread: 12 ProcessThread5
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000700007304000
Exception Codes: 0x0000000000000002, 0x0000700007304000
Termination Reason: Namespace SIGNAL, Code 10 Bus error: 10
Terminating Process: exc handler [2438]
VM Region Info: 0x700007304000 is in 0x700007304000-0x700007305000; bytes after start: 0 bytes before end: 4095
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
Stack 700007282000-700007304000 [ 520K] rw-/rwx SM=PRV thread 12
---> STACK GUARD 700007304000-700007305000 [ 4K] ---/rwx SM=NUL ...for thread 13
Stack 700007305000-700007387000 [ 520K] rw-/rwx SM=PRV thread 13
  • HARMAN_EEldeHARMAN_EElde Posts: 1,338
    Thanks for the information I will pass on to the dev
  • @Broadwood said:
    Hi
    Regards
    Nick
    User ID: 501
    Report Version: 12
    Thank you for this!
    Thank you for all the continued communication in support emails. Here's hoping the update comes out soon!
