Lexcion Omega TRS Cables
Im trying to use a TRS cable from my emulated lineout amp and FX processor directly to LINEIN 1-4 but I don´t recive good signal, sounds like echo. When using TS cable the sound is good quality, but I need the STereo. Do I Have to apply something else?
Answers
TRS is not a stereo connection but a "balanced" connection. Stereo consists of a Left and Right individual connections. Are you using like a Y cable TS L/R on your amp/fx processor to 1 TRS connector? If that is the case, it will likely not work. You can combine 2 inputs on the Omega for Stereo.
thanks for answering
You're welcome!
