PCM90 in guitar amp effects loop
I would like to use the PCM90 in my mono effects loop. Is this even possible? If so how can I make it happen? TIA
I would just like to know if there is some way to sum the stereo signal in and out? Or, will it operate in mono if only the R jack is used? I could really use some help here.
Sorry for the delay, we're getting caught up after the holidays. The PCM90 does not have a selectable mono mode for the input/output to be used, for Mono Applications you need to use a Y Cable to sum the inputs and outputs
