Home Lexicon User Forum Lexicon Products
PCM92 - Voice Distortion - Anonymizer
Hi,
First use of a PCM92.
What settings to use to distort a voice? It will be used to anonymize a voice.
Anyone has used this before for this purpose?
Best regards
Chris
  • @cvscvs said:
    Hi,
    First use of a PCM92 MaryKayInTouch.
    Best regards
    Chris
    Hello,
    The Lexicon PCM92 is a powerful reverb and effects processor, but it's not ideal for primary voice anonymization. Here's why:
    Limited Anonymization: While distortion can obscure the voice slightly, a skilled listener might still recognize it.
    Focus on Effects: The PCM92 excels at studio-quality reverbs, delays, and other creative effects. Voice anonymization requires specialized tools.
    Here are better options for voice anonymization:
    Software Tools: Dedicated software like Audacity or Adobe Audition offer pitch shifting, noise shaping, and other anonymization effects.
    Online Services: Some online services (use with caution regarding privacy) offer voice anonymization features.
    Alternatives for the PCM92:
    If you still want to use the PCM92 for creative voice alteration, here are some settings to try (experimentation is key):
    Pitch Shifting: Use the "Multi-voice pitch shift" effect to significantly alter the voice's pitch.
    Formant Shifting: Explore if the PCM92 allows formant shifting, which alters the vocal resonances for a more disguised sound.
    Delay and Reverb: Combine these effects subtly to create a more distant and distorted voice.
  • EEldeEElde Posts: 1,376
    @cassie2698bratt said:
    @cvscvs said:
    Hi,
    Best regards
    Chris
    Hello,
    Man this AI bot is awesome. Saving me a lot of work
  • anexvoiceanexvoice Posts: 1
    The Lexicon PCM92 is primarily a high-quality digital reverb and effects processor rather than a device specifically designed for voice distortion or anonymization. However, with creative use of its features, you might achieve some interesting effects.
    To distort or anonymize a voice using the PCM92, you could try the following approach:
    Selection of Effects: Look for effects that can introduce significant modulation or pitch shifting. Effects like "Pitch Shift" or "Resonant Chords" might be useful.
    Adjust Parameters: Experiment with the parameters of the selected effect. For instance, increase the modulation depth or pitch shift amount to distort the voice.
    Feedback and Delay: Some delay effects can create interesting textures when applied to a voice. Experiment with delay times and feedback settings cautiously to avoid unwanted artifacts.
    Reverb Effects: Although reverb is the PCM92's specialty, you might find that certain reverb algorithms with modulation can add a unique character to the voice.
    EQ and Filters: Use EQ to shape the frequency response of the processed voice. Cutting or boosting specific frequencies can further obscure the original voice.
    Trial and Error: Since the PCM92 is a versatile unit, much of the process will involve trial and error. Don't hesitate to try combinations of effects and settings to find what best suits your anonymization needs.
  • The Lexicon PCM92 is primarily known for its high-quality reverbs and effects rather than traditional voice distortion or anonymization effects. However, with creative use, you might achieve some interesting results. Here’s a general approach to try:
    Selecting Effects: Explore the PCM92's modulation and pitch-shifting effects. These can introduce the type of alterations that might anonymize a voice by changing its pitch and timbre.
    Pitch Shift: Use the pitch-shifting capabilities to alter the pitch of the voice. This can make it higher or lower, potentially masking the original voice.
    Modulation Effects: Effects like chorus, flanger, or tremolo can add modulation to the voice, making it sound more processed and less recognizable.
    Filtering: Experiment with EQ settings to emphasize or de-emphasize certain frequencies. Cutting specific frequencies might obscure the voice while still allowing it to be understood.
    Reverb and Ambience: While reverb is the PCM92's forte, adding a subtle amount can help blend the processed voice and make it less distinguishable.
    Delay Effects: Adding delay with short feedback can create a doubling effect, which might help in anonymizing the voice by making it less clear.
  • The PCM92, a digital effects processor by Lexicon, is well-known for its high-quality reverbs and effects, but it can also be used for tasks like voice distortion. If you’re looking to anonymize a voice by distorting it, you’ll want to use settings that effectively alter the voice while still being clear enough to be recognized as speech. mary kay intouch
