Home Lexicon User Forum Lexicon Software
Lexicon Software Updates 2025 - Mac support / VST3 / iLok License Updates (DOWNLOAD HERE!!!)
HARMAN_PKarrHARMAN_PKarr Posts: 49
edited May 19 in Lexicon Software
Hello everyone!
I come finally with the updates you all have been waiting for. New updates for all Lexicon plug-ins are now available and downloaded through the Flux::Center app. These updates include support for Apple silicon natively and up to the most recent OS version Sequoia. VST3 versions now included on Windows and MacOS. iLok license updates are available to authorize licenses to machine. Make sure iLok License Manager is updated to the most recent version. The rollout of this license update may take time to affect all existing licenses, so please be patient with this feature. If it is not available for you yet, sign out and then back in to iLok License Manager and see if it resolves. If not, they will get to you eventually, I promise.
View our video highlights! - https://www.youtube.com/watch?v=CB63HYFQy14
Download Flux::Center here! - https://www.flux.audio/download/
*you will need a Flux store account to access your plug-ins. Once you have created a Flux store account, look for the option under your account to associate your iLok user ID with your Flux account. Once done, your plug-ins should show in the Flux::Center app under My Products.
This thread will remain open for questions. Please bear with me as questions come in. You are welcome to reach out to tech support via https://help.harmanpro.com, and those e-mails will be distributed between me and my other two colleagues here to assist.
We greatly appreciate the patience that you all have had with us throughout this time of adjustment and sticking it out.
«1
  • drifter7508drifter7508 Posts: 5
    edited May 19
    All these years waiting and now this?
    "*you will need a Flux store account to access your plug-ins. "
    I had it! As if it was not enough trouble to be forced to use iLok!
  • HARMAN_PKarrHARMAN_PKarr Posts: 49
    Understandable, but Flux::Center will at least keep your plug-ins updated. It's just for installing them, then you're free to never think about it again... until the next Mac updates roll around.
  • studiotonstudioton Posts: 21
    FINALLY FINALLY <3
  • TwelveTwelveTwelveTwelve Posts: 10
    Thanks for finally releasing however sessions which used the old VST2 version do not open with the VST3 version now. It's seeing it as a separate product instead of having the same ID so it replaces the old versions automatically.
    Please tell me the current behaviour is not intentional?!
    After some more testing it seems the new VST2 versions replace the old VST2 versions but there is a bug where the VST3 version does not replace the VST2 version. What should happen is if they share the same ID then the VST3 version should automatically replace any VST2 instance. Surprised such a fundamental bug slipped through after all this time.
    Good catch and to note. This is intentional in order to preserve the VST2 format because they will have different "ID"s. I realize this will be a little of a pain the more legacy sessions you have, but the workaround is to open the VST2 version and save a user preset. Both versions access the same preset folder, so you will then be able to load your preset saved from the VST2 version.
    I'm not sure there is an understanding about best practices with regards to VST2 and VST3 then? They should share the same ID. If you don't want to use the VST3 version then you don't install it and the host will see the VST2 version instead. Right now we can't install the VST3 version and have our sessions open as expected. That workaround means that we have to continue to have VST2 versions installed which kind of defeats the whole purpose to a degree.
    Since we're all on "legacy" versions at the moment this workaround just creates a huge headache for end users.
    Please reconsider as this is not how every other developer does it.
    I'm honestly really disappointed this is intended behaviour.
    edited May 19
    To reiterate and summarize:
    • VST2 has long since been discontinued. Users have been asking for a VST3 version.
    • If you have both VST2 and VST3 versions installed, the VST3 version should take priority and that's the one the user accesses.
    • Sessions containing the VST2 version should automatically migrate to the VST3 version. The user should be able to remove all VST2 versions from the system and have the sessions open with the VST3 version now and continue from there.
    • If you want to continue to use the VST2 version for whatever reason then don't install the VST3 version.
    • Having VST2 and VST3 versions with different IDs creates an administrative headache for the end-user. Having to open every single instance, save a preset, load the VST3 version, load that preset is frankly an insane and time consuming "workaround". It might be easy if you use the same preset all the time but when you tweak settings in a mix and almost every session is unique then it's a huge amount of extra effort.
    Again, please reconsider. As it is now the VST3 version is next to useless unless you're starting fresh.
    edited May 19
    I totally understand, believe me. I'll see if I can get an official response regarding this and see if there is a plan to update to support this but do realize that it is what it is for now and any fixes will be delayed as we await for the updates to get in people's hands and report such issues. The feedback is critical though, so keep it coming!
    edited May 19
    Thanks. I'll stick to the old version as right now it's just a headache with all the sessions and if it does change then maybe the new VST3 version will be incompatible. Still can't believe this was the intended direction.
  • machinatedmachinated Posts: 10
    Stoked to be able to use these again, thanks to all for making it happen. So far all working nicely.
    Please can the next update have either a reworked GUI, or at the least resizing and rescaling options?
    Further down the line, I’d love to see the individual plugins combined into a single bundle plugin (perhaps with a new GUI and more presets/algos). For now I’m just happy to be able to use these again.
  • ab459ab459 Posts: 16
    Hi TT, with all due to respect, but this is not always the case. Rather may vary by the vendor.
    Examples (who use method with differ ID, for vst2 and vst3): Softube, UJAM, Plugin Boutique, Korg, and many more.
    (Examples with the same ID ("replacing" method): Native Instruments, Izotope etc)
    So, this is definitely not a rule.
    Although, i can understand you as musician with needs for projects compatibility.
    But, there is some cases when "differ ID" method can be usefull too, for direct comparison one and the same version build behavior (inside the same DAW session), or betatesting needs for example.
    Just saying.
    edited May 20
    Just saying.
    Steinberg who developed the VST2 and VST3 spec outline best general practices. Of course not all developers adhere to those recommended practices.
    https://steinbergmedia.github.io/vst3_dev_portal/pages/Tutorials/Guideline+for+VST3+replacing+VST2.html
    I'm not sure about you but I would prefer to to open sessions and have it "just work" rather than spending time comparing VST2/VST3 versions. So you do a comparison once - great. That's a one-time thing versus opening sessions. As mentioned, VST2 has been long since discontinued so it's a bit of a moot point.
    I've also yet to hear a compelling argument as to why you'd want separate VST2 and VST3 versions (outside of comparison testing) with different IDs. Ultimately it creates more headache for the end user.
    For what it's worth I'm a mixing engineer and need project compatibility which (nearly) every other developer who migrated from VST2 to VST3 with their plugins does. Time in the day is short and my energy is better spent on the jobs rather than trying to do workarounds in software.
  • Hey there, I have a license for PCM Random Hall on my iLok2, but despite linking it with the Flux account online, my license there isn't showing? Any idea what's hiding it? Thank you!
    Sending you a message. Please look for me there.
    Just saying.
    Ok, I understand. Well, then the main thing I wanted to convey is that this is not an obvious error. Since other major vendors also use the method of different IDs.
  • Thanks heaps for the update, really happy that it finally took place. I am okay with the plugins looking the same as before, maybe could ask for resizing in the future but I would rather have stable and working plugins than other stuff as of right now.
    Resizing/scalable UI is in the works! The age of these plug-ins show obviously, but they are so old that the images are still bitmaps and need to be converted/updated in order to scale properly.
  • BassGuru222BassGuru222 Posts: 5
    edited May 21
    So excited! Thanks for the update. I agree that the VST3 version ID should match the old versions so your projects open seamlessly. I for one only have a few projects so far with the old version as I only purchased the bundle a few months ago. Still, if I had tons of older projects I'd like to open, that would be a pain.
    Let's be honest though... Who REALLY goes back to hundreds of OLD projects and remixes them?
    What's stopping you (us) from keeping the old versions in a backup folder and just use them when you need to load an older project? Maybe I'm missing something.
    Looking forward to resizable GUI and maybe a slightly updated Look? :)
    Pretty easy to answer that one. It's not necessarily about "remixing" a project but when a label requests something from a session potentially years down the line, you'd better have the ability to open it and make it work.
    Again, since VST2 has been discontinued and VST3 is the path forward, it's a no-brainer to expect it to do what it should do and migrate your session settings over to the VST3 version. DAWs won't support VST2 for much longer and it's not something I'd personally want to deal with having to time capsule the system (OS/hardware/DAW/plugins etc) for a developer that missed the obvious.
    Of course! I guess I'm just saying, if you have to open a project or two, you can save the preset from the old version and open it in the VST3 version. Not ideal, but not a "throw the baby out with the bath water" issue either. So far it's been stable. I'm not saying they SHOULDN'T fix it, but in the meantime it's workable.
  • Magnuschka369Magnuschka369 Posts: 1
    edited May 21
    Thank you for the update, special thanks @HARMAN_PKarr and his team.
    A little bit strange that we don´t have a new look for our beloved plugins, but I consider this as a first step in the right direction and looking forward to regular updates for our Lexicon PCM plugins.
    Please continue your work and make the plugins resizable, and if it is possible for you, bring the Lexicon PCM plugins in a fresh new look (in the way like on your preview pics in the old "update-thread").
    @HARMAN_PKarr: I will write you a PM regarding a personal wish, hope you and your team cold help.
    Also the possibility for the plugin owners to run the plugins without the Ilok key inside would be much appreciate for the future.
    Cheers
  • plfplf Posts: 11
    I‘m sooooo pumped for these updates!!!!
    Finally I can use these again after so many years. I had made a rule for myself to not use any physical iLok plugins since I‘m on the move a lot and it‘s just too risky not to be able to open a session because you don‘t have the right iLok dongle on you. So these new machine activations really are a godsend! And the Apple Silicon and macOS Sequoia compatibility, too, of course!
    Thank you so much to Lexicon and the Flux team for making this happen and for finally getting up some momentum again for these brilliant plugins after so many years of neglect! Really great!
    These are still the best reverb algorithms out there in my book.
  • plfplf Posts: 11
    edited May 21
    Regarding the requests for more modern GUIs that others have made:
    It‘s amazing to hear that high-res and scalable GUIs are in the works!
    But other than that, I actually like the old school look of these plugins and I don‘t think this look needs to change into something more modern necessarily.
    I mean, they look like the PCM 96 hardware, just like a thousand other plugins look like the hardware they emulate, and nobody is complaining or asking for a more modern GUI there.
    What would be a nice workflow enhancement though is if all seven PCM reverb plugins were merged into one single reverb plugin with a switch for the algos. It‘s just faster to switch the algorithm within an existing plugin instance than to have to load up a new plugin every time you want to switch from e.g. hall to chamber.
    +1 for an all-in-one plugin with all algos!
  • BlackDoorsBlackDoors Posts: 3
    Very good to be 'back in the room'! Have missed PCM a lot! :)
  • plfplf Posts: 11
    edited May 22
    @HARMAN_PKarr about the iLok machine activations: Is this some automatic process that's running now but that's just very slow or is it something that the Flux/Lexicon team still needs to do?
    Asking because this still hasn't happened yet for me even though it's been a couple of days since the release and I can't imagine any automated process taking this long.
    I have the latest plugin versions and iLok License Manager version installed. Logging out and back into my iLok account doesn't change anything. Is there anything else I need to do?
    Can we get a rough estimate of by when to expect this to have happened for all license owners?
    We are aware of this and in contact with Pace about it. The authorize to machine function is rolling out, as we have seen plenty of users able to take advantage of the feature, but we were not sure how long the whole propagation process would take. It's in the program, but if you're waiting on your license to show machine auth just hang tight!
  • All working beautifully in Nuendo 14, access to VST2 for older projects just loads up the latest version of that plugin, and it enables me to copy paste the settings of that reverb to the newer VST3 version, I like the options, I like the GUI refresh (much sharper now). Any way to access your documentation on all the changes/revisions/improvements you've made, like a PDF? thanks.
    @nickhintonmusic Curious how you manage to copy/paste the settings from VST2 -> VST3 version in Nuendo 14 without having to save a preset in the plugin itself and then load it in another instance.
