Connecting an external EQ to the EFX12?
How can I connect an external Peavey Q215 EQ to the EFX12?
I've tried sereral configuations with no success!
I use Active Speakers and active monitors..
Best Answers
OptionsRLW Posts: 6
There are a couple ways to do this. You could come out of the EFX12 main outs into the inputs of the Peavey, you will need XLR to 1/4 cables to do this. Make sure to keep the signal balanced. Then come out of the peavey into your active speakers, again with 1/4 to XLR cables. Another way is to get insert cables and use the insert jacks on the LR outputs. Then connect your active speakers as normal. Here is an example of an insert cable: https://www.amazon.com/Hosa-STP-202-inch-Insert-Cable/dp/B000068O1O/ref=sr_1_3?ie=UTF8&qid=1539701845&sr=8-3&keywords=insert+cable+trs+1/4"+to+2+ts+1/4&dpID=31PZ%2B6uHHgL&preST=SX300_QL70&dpSrc=srch
2
