Using UiMixer on I Phone X
Hi I'm seeing some unhelpful behaviour of the UI on iphone X
The main problems are that it will only work in landscape mode and when in landscape mode the home bar is too close to the faders so that you can't operate them. Plus the main panel does not let you scroll up so you cant get rid of all the stuff at the top like the address bar, in short I cannot use it!
I don't know if this is the wrong section, so I will take kind advice to post elsewhere if required
Nick
It only works in landscape mode by deign when rotated to vertical it will display the more me mixer adjustments. I have not had this issue with other iphones. you might try a different browser and see if that makes a difference. Also join the Ui24R Facebook user group and it has a large following and some of the members may have encountered this and have a solution. https://www.facebook.com/groups/SoundcraftUimixerusers/
