UI24r and Global Tap funtion
Jeff_Garlick
Using Global Tap function does not change the delay time on FX. BPM changes but actual delay output doesn't. Am I missing something?
Answers
I discovered the same issue
That would be great!
Sorry I cant answer your question directly, but would recommend a quick call to Tech Support. They would be able to tell you if it's operating as it should or if there is an issue.
Furthermore, if this is a feature request you'd like to see added, I can let the product teams know about it.
