Home Soundcraft User Forum Soundcraft General Discussion
Anyone using Cakewalk?
I recently purchased a Ui24R and am unable to connect it to Cakewalk. My PC recognizes the unit - but Cakewalk does not. Any advice would be greatly appreciated.
  • marcopolomarcopolo Posts: 11
    edited March 2019
    Ouch! I am using cakewalk and was planning to purchase a Ui24r. It comes with ableton lite! DOES NOT MAKE SENSE...8 input audio... ?? I will follow your post, please indicate if you managed to get it working with cakewalk. Thanks.
    Have you tried..the driver for windows ?
    Multi-Channel USB Audio Driver Setup v3.20.0 (Windows)
    https://www.soundcraft.com/en/softwares/multi-channel-usb-audio-driver-setup-v3-20-0-windows
  • I use Sonar and also Guitar Tracks Pro but only record one track at a time. I know that if I had a multiple in and out interface I would have to map the inserts to the tracks. You probably know this already, but if not this may be the problem.
    Jamespcostello any success with the windows driver?
