Expression 3 reloading on its own
I recently had a situation where the mixer reloaded a show file (other than the one I was using) all on its own. I was using the mixer with sound being sent to the mains and monitors. Suddenly the monitors quit working and all the faders were changing their position and some of the lights were changing status. All this occurred when I wasn't touching anything at all. You can imagine what kind of chaos this would create right in the middle of a show. Has this happened to anyone else out there? What did you do to fix the problem? I'm using firmware version 1.6. I don't know if upgrading the firmware would fix this issue.
Answers
I would suggest an upgrade to 1.8 if you haven't already. Also check to see if cue recall from MIDI or HiQnet is enabled. Both of those sources can be used to trigger cue recall.
