Signature 12 stereo out
Hello all. Quick question about my Signature 12 mixer. I plug a mic into the XLR, set gain, volume, eq, pan hard left, route it via the MST button to the Master Stereo outputs, and run a cable from the Master left XLR output to my Bose L1 PA system, which is mono. I bring up the Master volume, yet I get no sound. The only way I get sound is when I route the signal via the GRP button to the Group busses, and then cable from the Group output to the Bose. Any thoughts or suggestion? Your help is much appreciated.
Well there you go. After decades of tinkering in sound reinforcement and recording, I'm still capable of making a rookie mistake, such as assuming all cables are in good working order. Problem solved.
