Si Impact questions.
With the new firmware upadate for the Impact, can I split each of the 32 local inputs to each have two fully processed channels only sharing preamps? Looking for a board we can split to use as FOH from an ipad, and separate channels for monitors. Also, can you use two impacts networked together using one as a stagebox and monitor boardand the other out at FOH?
Answers
  • There is a manual that covers this for stage box and MADI configurations. You will need the dual MADI card to have a FOH split to a separate board. You don't have to split preamp signals, just use a different stereo mix controlled by the IPAD. Each mix has it's own set of processing.
