SI Compact "Error importing show" (error code 8)
I am unable to load stored shows. Always comes up with "default show" and after first attempt a yellow triangle with exclamation mark appears at top right of display. (Version 3.3 build 6)
Hi Roland, do you mean SI Impact instead of "compact"?
Maybe you run into an firmware confilct. If you have updatet your desk to the latest firmware maybe you older files are no longer compatible.
