Si multi digital card - using same audio channels on ADAT and USB ?
Hi, I need some direct out to be on both ADAT & USB. As the console only allows to route 1 Direct out, is there any way for the multi digital card itself to duplicate a "bank" of 8 channels of the USB out also to the ADAT out ?
(via th DIP switches or so)
Answers
I would suggest reading the various option card manuals if you haven't found a solution to this already. It is hard to help without knowing which console you are asking about. I hope you found a solution. From my experience with the SI Expression 3, I believe that 1 direct source can be mapped to any set of physical outputs you wish.
