Notepad 12FX and external effects
Hi!
sadly but I can't understand how to use external effect on this mixboard. Let's say I'd like to use some effect pedal as external fx.
Well, I already tried to plug console's channel 11 to pedal's input and wire its output back to channel 12 but with no success. Obviously that approach is wrong.
There are quite a few words in console's manual about external fx routing.
I will really appreciate if someone share the knowledge how to make things work.
  • Channel 11 and 12 are for input from an effects unit. The idea is to use the blue knob as a aux mix to send to the effects through the aux output. Then the effect’s sound is available for the main mix.
