Is it necessary to turn off the power of the mixer (notepad 8)?
Or if it is always on it will not hurt him?
It’s just inconvenient to climb under the table and unplug the socket every time.
Answers
  • Did you ever find out the answer to this because I also want to know if it's safe to just power everything off from the main power.
  • yuripavlyuripavl Posts: 3
    edited April 2020
    "Thank you for contacting Harman Professional Solutions.
    We understand you have a technical issue/query; however, first contact for support is via your in-country distributor.
    Please contact them and they will be able to assist you."
    In general, sent away
  • Moi j' ai une prise avec un inter et aucun problème
  • My general response to this is if you aren't using the mixer almost daily then it's not a bad idea to turn it off. You might consider adding a power strip with rocker switch that's a bit easier to access than having to crawl underneath and pull the cord out of the wall.
    This question is one that has been going on for the last 40-50 years and there probably is no right answer.
