Signature 12 not recognised by MacBook Pro
Hi, Just got a very strange (and annoying) bug. My Soundcraft Sig MTK12 suddenly doesn't show up in my sound options, anywhere on my computer (MacBook Pro). I've tried resetting the PRAM, the SMC, cleaned up kernel files, everything I can think of, but no luck. It dod happen once before, but I think with a reset SMC it all came back, but here nothing helps.
What's stranger is that everything else shows (when plugged in at the USB) - memory stick, SystemEx Library works fine between a synth and the computer.
So, can someone out there make a suggestion, I'm very frustrated by this, especially as we're locked down, so I can't even rush out and buy another mixing desk.
Thanks in advance.
I've had the same problem for a while now and no one has a solution. Many others have this problem on the forums but Harman is unresponsive here. I just messaged them on Twitter so let's see if they even respond...
might be at this link for two capacitors, $2.00 fix, going bad on the USB power rail. see following link and scroll down to post by gelabs on july 8th, 2018. it fixed mine.
https://www.gearslutz.com/board/low-end-theory/1055612-soundcraft-signature-mtks-status-32.html
