SoundCraft UI24R MIDI In/Out
Hello. I have a question to software developers. Are you planning to release software or PC/MAC driver for MIDI control of UI mixer parameters from a computer or laptop? At the moment there is an application from a Russian developer, which allows you to bind the midi controller to the parameters of UI mixers. But there is nothing similar in order to be able to, for example, control the delay parameters, or faders, or changing presets, using automations in Reaper or other DAW. That would be very helpful 4 live perfomances. I will leave you links for acquaintance with the Russian development.
https://youtu.be/fVmCtGISOpI
https://www.beseda.us/uimixer/
https://apps.apple.com/us/developer/pavel-beseda/id1485225675
Another Question: Can you add loading of custom cabinet impulses from external drive (and midi-control amp simulators)?
