Soundcraft Ui12 on MacBook or iMac (Logic Pro X)
Hello, I would like to use my Soundcraft Ui12 digital console as an interface in Logic Pro X on my iMac Pro ... Could someone help me configure it? Thank you
Answers
Hi Jonatan. 1. Make sure that the Ui12 Driver is installed. you can check it by going into your system preference and look for the speaker icon. then check your input/output to see if Ui12 shows up. once it is there you can highlight it as the main input/output. 2. Them Launch Logic Pro X and in your audio preference select the Ui12. Hope that helps
