Si Impact: Stereo monitoring on MTX1
Hi all,
wondering if you could help me find out what's going on.
For a live stream, I have 3 stereo MIX's that I feed into MTX1 which is also setup as stereo. Everything works fine to the outputs and is stereo all the way through, even into the stream, so that's all great.
However, I want to listen to the final matrix mix using a headset on the board but the MTX1 doesn't give me stereo when I listen to it, while all the MIX's DO give me stereo... Even looking at the monitor volume level indicator at the board, while I know that I should only get a left volume indicator in my test, both left and right indicate volume..
How come I get stereo all the way to the outputs and also in monitoring the MIX's but my monitor for the matrix, doesn't give me stereo??
Thanks a million for any help!
Edwin.
  • Same here. While monitoring any matrix, with right channel panned hard right, no audio is passed to the monitor headphone jack. XLR outs are sending stereo.
    As I pan the right channel left, it passes audio signal, but it is summed, not stereo.
  • keyboardjimmy777keyboardjimmy777 Posts: 16
    edited May 2024
    So I just updated my Performer 3 to 2.1 build 5. Voila. I get stereo out of the headphone monitor jack now and they fixed the labeling on the matrix to get the L and R proper. Thanks Soundcraft. I still love my Si's. They do things that the A&E SQs cannot. Like 64 inputs, 4 matrixes, 14, auxes, the SQ doesn't go there. Plus I still like the fast layout on the Si's console, especially for monitor mixing. Now fix the app and allow MUTE GROUPS to be a function on the app. I use Mixing Station and that app smokes the Soundcraft app. Way faster to get around. Way better use of screen space. I know your logo looks cool, but man, we need more functionality. We know it's a Soundcraft.
