SI Impact to stagebox connection
Hi guys,
The venue I work for just purchased a used Si Impact and stage box. It did not come with the cat 5 cable though. We have a cat 6 cable but I'm unable to find any info if it's compatible. Any help greatly appreciated.
The stageboxes don't come with any cable. CAT6 should be fine- what's the length of the run? Cable spec gets more critical as you approach 300 feet. In general.. high quality CAT cable intended for AV applications should be fine up to 200 Feet as a rough estimate. There's several variables that play into this. Our standard spec is an unshielded CAT5
I would expect no issues at that length.
