Never had issues w/ ASIO drivers, but WDM seems a nightmare - any insights?
I've got a USB Ui24r that I'm connect to a DAW (Cakewalk) to through USB. ASIO drivers work hunky dory, but due to ASIO protocols in DAW, I can only "light up" one set of ASIO drivers. I was advised to switch to Windows 10 "WDM mode" and the same restrictions wouldn't apply.
The ASIO drivers are listed as 32/32 and the WDM drivers are listed as 16/16 - but they're stereo, so essentially that appears equal. The trouble? I can't get them to work. All I get is pink noise.
In the picture below, I've got a mic attached to channel 10 on the mixer. When I light the channel input up ... it pins the meter. The mapping scheme - correlated from ASIO presumption is as follows (in WDM):
Channel 1 - Main Bus
Channel 2 - Aux 1/2
Channel 3 - Aux 3/4
Channel 4 - Aux 5/6
Channel 5 - Aux 7/8
Channel 6 - 1/2 hardware
Channel 7 - 3/4 hardware
Channel 8 - 5/6 hardware
Channel 9 - 7/8 hardware
Channel 10 - 9/10 hardware
Channel 11 - 11/12 hardware
Channel 12 - 12/13 hardware
Channel 13 - 14/15 hardware
Channel 13 - 15/16 hardware
Channel 14 - 17/18 hardware
Channel 15 - 19/20 hardware
Channel 16 - 21/22 software
IS THIS ACCURATE? If not, please advise. Is there a secret to getting them to work? I can't seem to do it, and I'm pretty tech savvy.
What am I missing/doing wrong?
Link to photo:
https://www.facebook.com/photo.php?fbid=10224708012268262&set=p.10224708012268262&type=3
I don't have any experience dealing with this and i doubt Soundcraft Tech Support would either (but could be wrong). If you are not already a member i would suggest joining the Ui24R Group on Facebook. There are some bright folk there including the original Ui24R product manager/designer so you will likely have better luck getting an answer.
