Mixer RM100
Hello,
What is the correct method for adjusting the input level of the RM100 mixer ?
Do you have to align the 0 dB on the Vu meter in cue mode with a fixed signal of 1000 Hz ?
Thank you for your advice.
Best regards.
  • If it's a line level signal that likely will work or get you in the ball park. In general doing the same thing using program material whether it is someone speaking on a microphone or CD playback would probably be better.
