hello house..
what are the causes of channel bleeding on ui 16 mixer? i got to church to discover that the mixer is showing that there is an input signal on the channels of the mixer but there was no input... this is causing a big issue on the master output. please what is the cause?
I have updated the firmware but the issue still remain. i have also done a reset but there was no solution...
please I need help
Answers
Check your gain settings. What does the signal sound like? I would suggest also looking though all of your signal routing and levels and check the signal generator to make sure it is turned off.
May be a ground loop...
