sample rate
How do I check/change the sample rate on the signature 22 mtk?
Answers
You would do this through the Soundcraft USB Audio Control Panel. Link to program if you haven't already got it is here https://www.soundcraft.com/en-US/softwares/soundcraft-multichannel-usb-audio-driver-v3-20
One thing to note is that the actual sample rate is set via your computer audio settings. I believe the Signature will only work at 48K or 44.1K. The Soundcraft USB Audio Control Panel does have a sample rate window but it just pulls the sample rate from the computer and as mentioned above you can't change it there.
Thanks but it looks like this is for PC, do you have a download for Mac?
The Signature is Mac Core Audio Compliant so no download is required. The Signature will ID as an audio interface under Apple Menu>System Preferences> Sound. Sample Rate settings will be set here as well
Thanks!
