Ui24R no USB
Hi everyone.
Is there a chance to full restore the Ui24R without USB ports working?
I can only connect via USB i/f to the computer.
Thanks in advance.
1
Hi everyone.
Thanks in advance.
Hello
I have the same behaviour, since March did you found a fix with USB not working? Regards.
I found that the USB port works when USB drive is FAT32 formatted. Larger USB drives require ExFAT formatting. This is not recognized by UI24R. Is there a firmware available or config setting that will enable recording USB t recognize ExFAT formatted USB device for recording?
UI24r will accept large drives, however, you MUST reformat the drive to FAT32 with an app, RUFUS is free and works great! Format a large drive as non bootable, Partition = MBR, File system = Large FAT32, Cluster 32kb
