Overdubbing
Without a DAW, What is the best 24 track recorder capable of overdubbing to use with the ui24r.
You need to use a DAW or some sort of computer based recorder as the Multitrack Interface is via USB for MAC Core Audio or using ASIO Drivers. For a stand alone recorder you would need to use Dante, MADI, or Analog.
Obviously you could record directly to a USB Stick and then and transfer to a device that can accept .wav files as imports. I think the JoeCo Blackbox Recorder. All in all its probably easier to use some sort of DAW
Thank you, very helpful.
