Computer sound
I have a Signature 22 MTK. I can get sound for input mics and instruments. How do I sound out from the computer into the board?
I'm working with a Windows 10 PC
OK, I found the answer, I had to change the sample rate from 48,000 to 41,100.
The next question is why won't it work with 48,000? Is it driver updates needed or is it deeper in the code or firmware? Are there plans to update?
The sample rate in the Soundcraft Audio Control Panel is derived from whatever sample rate is set under Control Panel>Hardware and Sound (or the Windows 10 equivalent). SO.. make sure you have chosen 48K on your computer.
