Cascade mode not working
Hello,
I try to get the cascade mode working. The firmware: 3.3.8293-ui24 is equal on both units. and the have the same unique ID.
In general everything seems to work well. I try the 1 example of the Ui24R_addendum_V3_original. And on the side of patching everything looks like the pictures in the example. I see on the first gliders also CS-1 and 2 on the bottom and no gain control (logic).
But no signal is coming trough. Any suggestions ? It looks like the cascade bus itself is not working. Thanks.
1
Reading the manual is always useful. "Physical Cascade ConnectionBetween Ethernet #2 ports:Directly connect the Ethernet 2 ports found on the side of each Ui24R together using a standard CAT5e or CAT6Ethernet cable. This must be a direct connection. Itcannot work going through intermediate switches or routers. Soundcraft has tested this connection upto 100feet"
https://3e7777c294b9bcaa5486-bc95634e606bab3d0a267a5a7901c44d.ssl.cf2.rackcdn.com/product_documents/documents/7495_1548346954/Ui24R_addendum_V3_original.pdf
IT WORKS ...
I have the same problem. All connections it's ok, but no signal is coming trough.
Any suggestions ?
Any suggestions ?
