Replacement Faders for a MFX 8-2 Desk
Hi All,
I'm cleaning up a Soundcraft MFX 8-2 channel desk and need to replace all the faders.
I have emailed both Soundcraft and seperatly SoundTech and had no response.
The faders are labled:
10KΩ A 842B (mono channels) (x8 required)
10KΩ A 833B (Stereo/EFX/Output channels) (x6 required)
Is there a reasonably priced compatible fader out there from the likes of CPC/Farnell/RS/Rapid/Ebay?
I also have an issue with one mono channel which has the signal present LED permantly lit. With a signal going through the channel it has no effect on the LED. The rest of the channel works correctly.
I've been searching for a service manual for this desk and am drawing a blank so I'm using a SC EFX technical manual as a guide. Is there a significant difference internally between the EFX and MFX ranges?
Many thanks
