DAW Connectivity with Ui-24R
Documentation I have found says that the Aux outputs 1 thru 8 can be received via DAW Channels 3 thru 10.
There doesn't appear to be anything on DAW channels 3 thru 10. There are signals on Channels 1,2, and 11-30.
I need to connect Aux 3 and 4 to a MAC. This signal should be on DAW 5 and 6 but nothing is found there. Is this the way it is?
