Home Soundcraft User Forum Soundcraft Stageboxes
Soundcraft ui 16
Hi guys. New guy here, my soundcraft doesnt boot up. The wifi and main lights keeps flashing. I tried reseting the unit using a fullreser.txt file but it doesnt work. Please help!
I got it from a friend, it is brand new in the box
I cant find it on wifi so i can acces it…
Thanks in advance
  • I'm having a similar problem. My ui24r all of a sudden went off. After restarting, it would not boot fully. A couple times it booted up but then went off. Now when starting it gets stuck on the the MIX L & R green lights glowing but will not go beyond that. I'm suspecting a hardware problem but trying to see if there is an easier solution first
  • Same issue as ui24r, it gets stuck on the the MIX L & R green lights glowing but will not go beyond that. im literally crying right now and don't now what to do
  • Same issue,
    someone found a solution ?
  • Same with my new ui 24 any one solve this problem
