why my ui24r don't recognize the usb stick?
I work With Guitar Center and bought the ui24r but it doesn't want to read the usb (any size)
Answers
ui24r
Yes, all of the sudden the same memory stick I’ve used multiple times before for multitracking is not loading or being recognized. Either does any other stock I try. Come on Harmon. This unit is used in the studio. The unit doesn’t even move.
The same situation with me. A firmware update is also not possible because no stick is recognised.
Furthermore, it is not possible to load a preset/snapshot, even if they are displayed in the menu for selection. Even after a restart, everything is back to the factory settings, except for the network configuration...
Wow, no responses on this. I thought I was buying quality equipment with a proven track record. Turns out, I guess, that they won't even acknowledge a common problem.
Next time I won't be buying Soundcraft!
