UI12 websocket connection
Hey everyone!
I'm playing around with my UI12 and communicating with it via websockets. I've found some projects on the web doing a similar thing, e.g. this one: https://github.com/fmalcher/soundcraft-ui/blob/main/packages/mixer-connection/src/lib/mixer-connection.ts
Also, there are videos on YouTube demonstrating how to control the interface with a CLI script and receiving its state changes from the network connection. Alas, I'm unable to reproduce it. Here is a minimal version of what I'm working on, written down in Python:
import asyncio import sys import time from websockets import connect # lib installed with pip alive = "GET /raw HTTP1.1\n" async def conn(host, port): async with connect(f"ws://{host}:{port}") as ws: await ws.send(alive) print(await ws.recv()) while True: await ws.send(alive) message = await ws.recv() if "SET" in message: print(message) time.sleep(1) # can be omitted without effect asyncio.run(conn(sys.argv[1], sys.argv[2]))
This works fine for a couple of seconds, during which I receive the unit's full state and updates from interacting with the web interface, but after that I only receive empty messages on my websocket.
I can control my device with the Soundcraft Midi Mixer application just fine, so I doubt there is a fundamental difference in the protocol between my UI12 and e.g. the UI24r, which most examples on the web refer to, as well as that I'm experiencing networking issues.
I also tried using a raw TCP socket, which gave me the same results (communication works for a few seconds an then dies down). My target language is Rust, where I can achieve the same (I just chose python for brevity here), so it's also not an implementation detail of either Python's or Rusts's websocket/TCP stream API that's spoiling my mood here.
Has anybody here ever done something comparable and knows what I'm doing wrong?
Funny how things coincide sometimes, it's been just a few days since I found a fix/workaround for the problem myself.
tldr: Whenever I receive a ping-message, I have to send a certain message back. This is my working implementation in Rust (the language I wanted to use anyway):
A few things to take note of (see annotations in the code):
msg.is_ping()
). Both ways of operation don't work in conjunction with at least my UI12 though. I don't know if it's the library's fault or if the mixer meddles with the protocol messages, but I have to perform this sort of manual check & action.The above code however keeps the connection alive and will print (or rather
trace!
) any control signals the mixer confirms to have received.
