audio from computer to Ui24r ?
Hi , how do you get audio from your computer to the Ui24r , not your daw , just a MP3 player or another program with audio signal ?
Is it possible with the usb cable ?
Or do you have to go out of your computer into the rcf inputs (line in ) ?
  • TAICHEETAICHEE Posts: 269
    You just select the ui24r as your output of the OS.
    It's same as DAW. Non DAW app usually only use the output-1 and 2 although DAW use all of output 1-32.
