SI Impact Dante
I'm contemplating adding a Dante card to a SI Impact to route all the direct outs to another mixer.
I'm not an expert on the patching within the SI Impact, although I know Dante from elsewhere. I've been testing the configuration using the Offline Editor.
So far I have configured a Dante card in the "Modules" section. But the Offline editor is not showing me any of the Dante inputs or outputs. I must be missing some simple setting - but what????
EG: if I want to send The Mic01 signal that is assigned to Ch01 to Dante via the Direct out, I can see Analog outs 1 - 16 and the AES but not Dante (Or MADI for that matter)
Is there an "Enable" button for the option cards that I'm not seeing??
Ken
  • In the offline editor after you open the MODULES window and add your cards, there is a window that appears to the right of the madi card that allows you to configure the stagebox slots. The ins/outs won't populate in the menu until those are loaded
