Portable hard drive multitrack recording on UI 24
Hi. Can someone please talk me through the connections and process or multitrack recording to a portable external hard drive from my UI24. I know how to record multitrack to a usb flash drive but am wondering if I will connect the external hard drive to the same rec out usb slot and will the process be the same with the same procedure.
Answers
  • TAICHEETAICHEE Posts: 269
    You can do it.
    In usually the hard drive spend much current and the connection makes the unit reboot due to the overload.
    So you should use a Self-Powered USB hub for the REC slot.
