Their XLR output connectors are “impedance balance”. ( aka pseudo balance. ) Basically these are unbalanced circuit but it works like balanced circuit has a merit of the noise cancellation.
Headphones outputs are definitely unbalance. Even if you used it as an optional aux output, unbalanced is unbalanced.
https://svsound.com/blogs/svs/what-are-balanced-xlr-audio-cables-svs-sound-experts-blog
xlr are normally balanced.
yes they are balance also the headphone out when switched to aux out should be balanced on the ui12 and ui16
