SI Impact Routing Question - Selecting channels for a Second Output
Hey All, I should know this but just not figuring it out... I installed an SI Impact mixer in a church, and I have mixes 15 and 16 going to the L & R FOH cabs as expected. I did a Copy of 15 & 16 and pasted the settings to 9 & 10, to essentially clone the output. 9 & 10 feed the audio interface for the streaming audio. They have 24 channels being used, but I simply want to NOT send channels 23 and 24 to the cloned 9/10 output. Is there a simple way to set up the Impact to do that? The main mix feeds both sets of outputs which is working for the limited soundman help they have in the church, but if a full separate mix is the only way then we can go that route if need be. It'd be simpler for them to have one mix if possible (it's a Baptist church, only vocals and piano, not a complex mix). Thanks MUCH in advance.
