Home Soundcraft User Forum Soundcraft General Discussion
Soundcraft ui 24r usb I/f disconnects
I just purchased a used ui24 and while testing to make sure everything works I found this to be an issue. The ui24 usb if disconnects after a few minutes and the only way to get it back is to reboot the mixer. Should I return this? Is it a firmware issue? Or is the mixer damaged? Any help would be greatly appreciated. I only have a few days to send it back.
  • TAICHEETAICHEE Posts: 269
    Do you mean that “USB IF” as the USB memory stick slots ?
    Or USB-DAW port?
  • mmalvidommalvido Posts: 1
    edited January 2024
    I have the same problem, but it can be working ok for some time and suddenly stops sending signal to the mixer, until reboot. I am using an iPad connected to USB usb i/f
